How do I transfer a Cam Plus license from one Wyze Cam to another?
To transfer a license between cameras via the Wyze app:
  1. in the Wyze app, tap on the Account tab.
  2. Tap Services > and the three dots next to Cam Plus.
  3. Tap Manage Camera.
  4. Tap the check mark next to the cameras you want to move the license from and to.
  5. Tap Continue to save your changes.
👉 If you remove a Cam Plus license from a camera, that non-Cam Plus camera will only record still images instead of videos.
To attach a subscription to a camera via the Wyze website:
  1. Go to my.wyze.com and log in using your Wyze email and password.
  2. Click Account to open My Services.
  3. Find the subscription you wish to assign to the camera.
  4. Click Select Cameras.
  5. Check the box next to the name of the camera you wish to assign the subscription to.
    • If the box is grayed out, you are out of licenses. You must remove a license from a different camera, or add a new license to your subscription.
  6. Once done, click Update Cameras on the lower right-hand corner of the screen.
Additional Notes
  • Services (Cam Plus, Cam Protect, etc.) subscriptions have individual plans (or licenses) for you to assign to their compatible devices.
    • Example: Cam Unlimited includes unlimited individual licenses you can assign to unlimited cameras!
  • You can only transfer a Cam Plus plan to another Wyze Cam compatible with Cam Plus.
    • 👉 All Wyze Cams except Wyze Cam v1 are compatible with Cam Plus.
    Monday through Friday, 9AM-5PM UK Time
  • Join Our Community
