Event Recording and Schedules on your Wyze Cam v4
Create an Event recording schedule so that your Wyze Cam v4 only records videos during specific times. Don’t want Events recorded while you’re home in the evenings? Set your schedule to only record Events during the day.
Note: Without a paid subscription, your Wyze Cam will only generate a thumbnail image instead of an Event video.
Event Recording Schedules on Wyze Cam v4
Setting up an Event Recording schedule
You can set up a schedule for your Wyze Cam to record events:
  1. Tap Home, then the + plus sign. On the Add menu, tap Automation.
  2. On the Create Automation page, tap Schedule.
  3. Tap the + plus sign next to Name (Optional).
    1. Enter a name for the schedule. Try "Turn on motion detection"
    2. Tap Save.
  4. Tap the + plus sign next to Add Action.
  5. Tap the Wyze Cam you want to create a schedule for.
  6. Tap the box next to Turn on motion detection, then Save.
  7. Tap Start Time.
    • Select a time, then Save.
  8. Tap Add End Time.
  9. Tap the days you want the schedule to be active on.
  10. When done, tap Save.
Detects Sound and Motion
You can set your Wyze Cam to record an Event Video when it detects motion and/or sound. A subscription to Cam Plus is required for this feature.
  1. In the Wyze app, go to the Home tab and tap on your Wyze camera.
  2. Tap the Settings icon.
  3. Tap the Event Recording tab
  4. Tap to toggle on/off Record Motion Events and/or Record Sound Events.
Note: If neither detection setting is enabled, your Wyze Cam will not record Event videos itself, but can still pair with devices like Wyze Sense to record Smart video alerts.
Cool Down Period
When a Sound or Motion triggers an Event video there is a 5 minute cool down period.  Sound and Motion are separate triggers. So if a sound triggers an Event video it will have a 5-minute cooldown, but if something then triggers via motion, during that time period it will also trigger an Event video. Then there will be a separate 5-minute cooldown period for another motion-triggered video.
Note: A subscription to Cam Plus will remove the cooldown period and allow your Wyze Cam v4 to record longer than 12-seconds if there is motion detected. Learn more about Cam Plus.
Smart Sound Recognition
Smart Sound Recognition uses an advanced algorithm that recognizes the unique sound patterns of smoke alarms and CO monitors. With Smart Sound Recognition turned on, Wyze Cam v3 will record a 12-second Event video and send a push notification to your phone so that you can act quickly.
Smart Sound Recognition settings are found in Home tab > Wyze Cam v4 > Settings gear > Alarm Settings.
Here you can set the Smoke alarm sound and/or CO alarm sound on/off.
Note: If you have Detects Sound off, you can still use Smart Sound Recognition to receive a notification when the camera detects the specific sound of an alarm.
    Monday through Friday, 9AM-5PM UK Time
  • Join Our Community
