How do I share my Wyze Cam v4?
Sharing is a feature that lets other people access and use your Wyze Cam v4. Have a family member or other close friend who wants to view your Wyze Cam v4? Share it with them right from the Wyze app.
Important: Only share your Wyze devices with people you know and trust.
To share your Wyze Cam v4:
  1. In the Wyze app, tap on your camera.
  2. Tap on the Settings gear > Sharing.
  3. Tap on the + plus sign to share with a new user.
  4. Enter the email address of someone new to share with, then tap Search, then Share.
    • Or, tap on an email address from your Recent Shares. Then tap Share.
The shared user will receive a notification in the app to accept the Wyze Cam.
To stop sharing:
  1. Open the Wyze app, then tap Account > Sharing.
  2. Tap on the user you want to stop sharing with, then the edit pencil.
  3. Tap to uncheck the device(s) you want to stop sharing.
  4. Tap Update to save your changes.
What can a shared user do?
Shared users will be able to:
  • View the Live Stream and Event Videos.
  • Record a Live Stream.
  • Create Shortcuts, Schedules and Automations.
  • Move Wyze Cam Pan devices.
  • Enable and disable Motion Tracking.
  • Use the Sound, Speak, and Take Photo tools.
  • Turn on and off the device.
  • Turn on and off Night Vision.
  • View the Device Info.
  • Remove the device from their Wyze app.
Shared users will not be able to:
  • Share a device shared with them.
  • Rename a device shared with them.
  • Change the Detection Settings or Alarm Settings.
  • Shared users cannot view microSD card footage.
 Keep in mind:
  • There is no limit to the number of users you can share your Wyze devices with.
  • There is no limit to the number of Wyze devices you can share.
  • The sharing feature is set per camera. To share multiple devices, you'll have to invite users to each manually.
  • Only primary users of Wyze Home Monitoring can use the View Multi-Cam feature on the Monitoring tab.
  • Only shared users with no security plan can use the View Multi-Cam feature on the Monitoring tab.
    Monday through Friday, 9AM-5PM UK Time
  • Join Our Community
