How do I view my microSD card recordings?
You have a microSD card installed in your Wyze Cam, and you've enabled Continuous or Events Only recordings in your device Settings. Here's how to view playback from your microSD card.
Related article: Wyze Cam v4 MicroSD Card Troubleshooting
To view your local recordings*:
  1. In the Wyze app, tap on your Wyze Cam to launch the Live Stream.
  2. Below the Live Stream, tap SD Card.
  3. Tap and drag along the recorded footage to review it.
  4. To exit playback, tap Go Live.
If you have a Wyze Cam v3 or an older device, your local recordings look a little different.
To view local recordings on a Wyze Cam v3 or older**:
  2. Below the Live Stream, tap View Playback.
  4. To exit playback, tap Live Stream.
Additional Notes
  • You must have a microSD card installed in your Wyze Cam to record locally. For cloud storage, grab a security plan like Cam Plus!
  • You can have a security plan and a microSD card on the same camera at the same time.
  • Not all Wyze Cam devices have a microSD card slot. Wyze Video Doorbell v1, and Wyze Video Doorbell Pro do not have the local recording feature.
  • * Wyze Cams newer than Wyze Cam v3 are: Wyze Cam Pan v2, Wyze Cam v3 Pro, Wyze Cam Floodlight v2, Wyze Cam Floodlight Pro, Wyze Cam Outdoor, Wyze Battery Cam Pro, Wyze Cam Pan v3, Wyze Cam OG, Wyze Cam v4, Wyze Video Doorbell v2, and Wyze Duo Cam Doorbell.
  • ** Wyze Cams older than and including Wyze Cam v3 are: Wyze Cam v2, Wyze Cam Pan v1, and Wyze Cam v3.
    Monday through Friday, 9AM-5PM UK Time
  • Join Our Community
