How do I maintain my Wyze Scale Ultra?
Wyze Scale device maintenance tips:
  • Keep your scale clean.
    • As needed, wipe the scale surface with a cloth dampened with water.
    • Do not use bleach, organic solvents, or other chemicals on the scale.
  • Remove the battery if you won't use your scale for over a month.
  • Avoid shocks. Don't jump on it.
  • Do not disassemble your scale.
    Monday through Friday, 9AM-5PM UK Time
  • Join Our Community
