Release Notes & Firmware
Android App
2026
Android App 2026
3.22.1.979 (September 21, 2026)
  • Fixed an issue that prevented Android 17 users from using Wyze Thermostat.
  • Fixed an issue in the Friendly Faces registration flow that prevented Android users from seeing the correct registration button.
3.22.0.973 (September 16, 2026)
  • Improved in-app pop-up messages for low microSD card storage and microSD card errors.
  • Improved Motion Tagging behavior when Pan Scan and Tracking are enabled at the same time.
  • Fixed an issue where the Wi-Fi signal strength was displayed incorrectly during setup.
  • Fixed an issue where microSD card recordings could not be played back.
  • Fixed an issue where enabling the IR lights while the device was turned off did not take effect after the device was turned back on.
3.21.1.962 (September 3, 2026)
  • Fixed unresponsive device groups & devices on the Favorites page.
  • Fixed the price display issue on the service home page.
  • Fixed display and rendering issues with the Wyze Stories pop-up.
3.21.0.955 (August 31, 2026)
  • Added support for category-based and fuzzy keyword searches during the "Add Device" process.
  • Bug fixes.
3.20.0.941 (August 24, 2026)
  • Updates to the 60-day cloud storage experience.
  • Bug fixes.
3.19.0.935 (August 11, 2026)
  • Bug fixes.
3.18.0.918 (July 23, 2026)
  • Bug fixes.
3.17.0.904 (July 14, 2026)
  • Introduced guest shopping to allow users to browse products, build a cart, and complete checkouts without requiring an upfront login or signup
  • Bug fixes.
iOS App
2026
iOS App 2026
3.22.0.35 (September 16, 2026)
3.21.1.2 (September 4, 2026)
3.21.0.16 (August 31, 2026)
  • Bug fixes.
3.20.0.20 (August 24, 2026)
  • Bug fixes.
3.19.0.17 (August 11, 2026)
  • Bug fixes.
3.18.0.15 (July 23, 2026)
  • Bug fixes.
3.17.0.13 (July 14, 2026)
  • Bug fixes.
Wyze Firmware
Learn more about how to update a device's firmware by clicking here.
Cameras
Wyze Cam v4 Firmware
4.52.17.19 (September 14, 2026)
  • Fixed an issue that introduced more noise in audio.
  • Event upload stability improvements.
  • Network stability improvements.
Note: This firmware will be released gradually over the next few weeks.
4.52.9.6119 (March 23, 2026)
  • Fixed an issue that caused failed or slow live stream connections.
Note: Updating to app version 3.11 is required for a complete fix. If either component remains outdated, the issue may persist.
Lifestyle
Wyze Scale Ultra Firmware
1.1.8 (April 9, 2025)
  • Added logging functionality
  • Added Bluetooth® OTA update capability
  • Adjusted Bluetooth® wake-up function
  • Modified body composition display settings on the scale (Fat percentage and muscle mass are now optional but maintain their order)
  • Updated Wi-Fi firmware SDK
  • Fixed an issue where the fat percentage difference was incorrect when displayed as a separate page
  • Fixed an occasional reset issue
  • Adjusted Bluetooth® speed from 2M to 1M to improve anti-interference performance
  • Changed connection latency from 0 to 2 to enhance interference resistance (OTA update time increased by approximately 1-2 minutes)
  • Adjusted Wi-Fi firmware MSS to improve Wi-Fi OTA success rate
Miscellaneous
Wyze Web Portal
Wyze Web Portal
2.7.4 (July 11, 2024)
  • Minor bug fixes
    Monday through Friday, 9AM-5PM UK Time
  • Join Our Community
