My Wyze Scale Ultra’s battery level is incorrect.
Problem
The battery life on my Wyze Scale Ultra seems lower or higher than it should be.
Troubleshooting
  2. If possible, check that your Wyze Scale Ultra’s firmware is up to date.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Force close the Wyze app.
  4. Power cycle Wyze Scale Ultra.
    1. Remove the batteries from the scale for 10 seconds, then reinstall them.
  5. Factory reset Wyze Scale Ultra.
    1. On the back of the scale, in the battery compartment, find the UNIT button.
    2. Press and hold the button for 3 seconds until the TFT display shows "Clear".
    3. Set up your Wyze Scale Ultra as new.
    Monday through Friday, 9AM-5PM UK Time
  • Join Our Community
