Wyze Scale Ultra Setup Guide
To set up your Wyze Scale Ultra:
Before starting, insert the batteries into your Wyze Scale Ultra. Then place it on a hard, flat surface and enable Bluetooth on your phone.
  2. On the Add menu, tap Device.
  3. Tap Lifestyle > Wyze Scale Ultra.
    • Your phone will search for your scale, pair with it, and connect to it.
  4. Name your device or choose a pre-selected name, then tap Save.
    • You can add this device to your Favorites by leaving the box checked.
  5. Add your details (Year of Birth, Height, etc.).
    • You must be between 10 and 100 years old to get Body Composition data.
  6. Tap Next. Your phone or tablet will pair with your scale again.
  7. Step on the scale to activate it. Make sure your device's BluetoothⓇ is enabled.
    • Your weight will display on your device and Wyze Scale Ultra.
  8. A Setup Wi-Fi popup will appear. Tap Yes.
    • Or tap No to skip. You can set this up later in your scale’s settings.
  9. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
    • Tap the icon in the password field to display the password to ensure it was entered correctly.
  10. Once Wi-Fi has successfully connected, tap OK and you’re all set!
New to Wyze? Before starting, download the Wyze app and enable Bluetooth.
    Monday through Friday, 9AM-5PM BST
  • Join Our Community
