Wyze App Setup Guide
Every smart product from Wyze has a home in the Wyze app.
To get started with the Wyze app:
  1. Download the Wyze app from the Apple App Store or the Google Play Store.
  2. Once downloaded, tap the Wyze icon to open the app.
  3. Create a Wyze account, and/or sign in to your Wyze account.
    • To create a Wyze account:
      1. Tap Sign up on the app screen.
      2. Enter your email address, then set a password for your account.
      3. Tap Continue.
      4. Follow the on-screen instructions to finish setting up your account.
  4. Connect your phone/tablet to your 2.4 GHz Wi-Fi network.
    • Note: You must be connected to a 2.4 GHz Wi-Fi network to set up a Wyze device.
  5. Once you’re all set, tap on the + plus sign in the top right corner of the Wyze app then Device to set up your very first Wyze device!
Additional Notes
  • Wyze app version 3.0 and above is compatible with Android 10.0+ and iOS 16.0+ devices only.
    • Devices using a 32-bit operating system are not compatible with Wyze app 3.0.
  • Wyze app version 2.50 and below is compatible with Android 7.0+ and iOS 14.0+ devices only.
    • Using the Wyze app on an older device that doesn’t meet the requirements may cause compatibility issues.
    • Due to hardware/software limitations, not all Android or iOS devices may be compatible even if they meet the app requirements.
  • For devices running lower Android/iOS versions:
    • If the device already has the Wyze app installed, you can continue using it, but you will not be able to upgrade to a newer version of the Wyze app.
    • If the Wyze app is uninstalled from your device, you will no longer be able to reinstall it.
  • The Wyze app is not compatible with Windows phones/tablets or Kindle Fire tablets.
  • If you have any problems downloading and using the Wyze app, make sure your device software is up to date.
    Monday through Friday, 9AM-5PM UK Time
  • Join Our Community
