Navigating the Monitoring Tab
You can quickly view and manage your Wyze Cam live streams from the Monitoring tab in the Wyze app. With a subscription to Cam Unlimited, you can arm/disarm your cameras for self-monitoring.
🛡️ The Monitoring tab is your self-monitoring hub for all your compatible Wyze Cams. You can monitor up to 4 live streams simultaneously with Multi-Cam view, review event recordings, and arm/disarm your cameras* — all on this screen.
*Self monitoring (Disarmed / Home / Away) requires a subscription to Cam Unlimited or Cam Unlimited Pro.
This article covers the following topics about using the Monitoring tab:
  • What is on the Monitoring tab?
  • How do I view each camera live stream?
  • How to enter landscape mode?
  • How do I switch modes?
  • How do I edit my monitoring settings?
  • How do I edit the cameras in multi-cam view?
  • How do I remove cameras from multi-cam view?
  • How do I review event recordings?
To edit the cameras shown in multi-view:
  1. In the Wyze app, navigate to the Monitoring tab.
  2. Under the multi-view of the live streams, tap the camera and pencil icon.
  3. Drag and drop and sort the cameras which you want on the specific page.
  4. Tap the back arrow <. Your changes will save automatically.
Please note: You can only add up to 16 cameras over 4 pages. If you have more cameras, they will be shown under Available Cameras. They will not be added to multi-view.
To remove cameras from multi-view:
Tap and drag the camera from the page.
You can also quickly look through events and locate particular AI events using the timeline feature. Underneath the multi-view, you will see a timeline that contains the Event videos for your cameras. Simply tap on an Event to view it.
Please note that this timeline will only show Events associated with the cameras being shown in multi-view. Recordings for any other cameras can be found in the main Events tab of the Wyze app.
The Monitoring tab is also where you can access your Cam Unlimited settings.
To access Cam Unlimited settings:
  1. Tap the drop-down arrow in the upper right-hand corner.
  2. Tap Settings.
  3. From here you can adjust the camera modes and notifications.
    • You can learn more about modes here.
    Monday through Friday, 9AM-5PM UK Time
  • Join Our Community
