My Wyze Cam v4 has poor image quality.
Problem
The live stream is blurry or discolored, there is a purple or pink tint to the picture, there are lines in the image, or you are otherwise experiencing poor image quality.
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. Check that your camera's firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Ensure there is nothing impairing the camera’s lens.
    1. Remove any plastic film or cover on the lens.
    2. Gently wipe the lens with a soft cloth to remove any dust or debris.
    3. If there is a third-party cover on the device, please remove it.
    4. If the camera is used behind a window, check that the window is also clean and transparent.
  4. Verify that there are no additional light sources next to or pointing toward the camera lens that may cause interference.
    1. If the camera is in the direct path of the sun, it is possible a lens flare appears in the image. You can adjust the position of the camera angle, but this is an expected phenomenon in standard cameras.
    2. If the camera is not facing the sun directly, make sure the camera’s spotlight isn’t reflecting off the ceiling.
      • We recommend adjusting the height of the camera so the reflection is minimized. We recommend about 1 foot away from the ceiling.
      • Optional: You can use anti-reflective tape on surfaces that would reflect the spotlight back to the camera at your own expense/discretion.
  5. Adjust the camera resolution.
    1. From the camera’s live stream, tap the resolution icon to toggle between the modes.
    2. Note: We recommend setting it to 2K resolution.
  6. Cycle through Night Vision Mode.
    1. Navigate to the camera’s settings > Advanced Settings.
    2. Under Night Vision Mode, cycle through Auto, On, and Off.
    3. Note: We recommend setting it to Auto.
  7. Restart the camera.
    1. Navigate to the camera’s settings > Restart Camera > Restart.
  8. Power cycle the camera by unplugging it from its power source for 5 seconds and then plugging it back in.
  9. Factory reset the camera and then set it up as new.
    1. Remove any microSD card that is inserted into the camera.
      1. If you have one installed, you must remove the microSD card before resetting your Wyze Cam v4.
    2. Ensure the camera is plugged into power and powered on.
    3. Pull the base away from the bottom of the camera. The next step will reset your device.
    4. With the camera powered on, press and hold the SETUP button on the bottom of the camera for 10 seconds.
      1. Single-pressing the SETUP button will not reset your Wyze Cam v4. You must press and hold the SETUP button for 10 seconds, until the status light turns red, to reset the device.
    5. Once the status light starts flashing red, the camera is fully reset.
    Monday through Friday, 9AM-5PM UK Time
  • Join Our Community
