Yes, by tagging your garage door as open or closed in the Wyze app. You can also help train Wyze AI by uploading images to improve the accuracy and detection of this feature.
- Is my Wyze Cam wireless?
- Motion Tagging on your Wyze Cam
- Event Recording and Schedules on your Wyze Cam v4
- How do I share my Wyze Cam v4?
- Does Wyze Cam v4 support 5 GHz networks?
- Does Wyze Cam v4 work with my Wi-Fi 4 router?
- What's the difference between Wyze AI and Edge AI?
- How do I record to a microSD card while offline?
- Can I view my Wyze Cam v4 on my smart TV?
- Which Wyze Cams have Motion Warning?
- See more
